No acquisition card !
  • gandrew
21/02/2021 22:11 #92620 da gandrew
Risposta da gandrew al topic No acquisition card !
Hello, thank you for your answer.
I wanted a light configuration of a single PC without external sound card or mixer, using RadioDJ and MB Recaster. However, it seems that's too simple.
I'll complete the configuration with a mixer. I'll use from the audio output of the PC sound card to the mixer and from the USB output of the mixer to a USB input of the PC.
Is MB Recaster able to pick up sound on the USB port?
22/02/2021 18:01 #92621 da MB RADIO
Risposta da MB RADIO al topic No acquisition card !
yes, if your mixer is visible and activated in the windows control panel / audio / enregistrement you can use it with MB RECASTER
  • gandrew
25/02/2021 22:37 #92637 da gandrew
Hello, I installed the mixer and all is working.
Thank you
