No acquisition card !
  • gandrew
20/02/2021 18:19 #92606 da gandrew
No acquisition card ! è stato creato da gandrew
I used MB Recaster Free 4.6.5.6 or 5.0.0.8 on Windows 10 and I got the same problem. I'm back in 4.6.5.6.
I'm using the default card of the PC.The "Acquisition card" field is empty but the "sound card listening" field is filled.
Please see the screenshot
File allegato:
Nome del file: Imagestudioradio.rtf
Dimensione del file:1,508 KB
20/02/2021 18:35 #92607 da MB RADIO
Risposta da MB RADIO al topic No acquisition card !
Maybe you want to capture a "loopback"? if so you must enabled the loopback in the options and restart
  • gandrew
20/02/2021 18:56 #92608 da gandrew
Risposta da gandrew al topic No acquisition card !
Thank you for your answer.
I enabled "loopback". I restarted MB Recaster and now I get "illegal device number".
I can select the card in "acquisition card" but I've a loopback. :(
20/02/2021 19:06 - 20/02/2021 19:06 #92609 da MB RADIO
Probably the input that you want to use is not enabled in windows. Show me the cards that you have in windows control panel audio
me i have this:
Ultima Modifica 20/02/2021 19:06 da MB RADIO.
  • gandrew
20/02/2021 19:22 #92610 da gandrew
20/02/2021 19:29 #92611 da MB RADIO
You must look at "enregistrement" not to "lecture"
  • gandrew
20/02/2021 19:42 #92612 da gandrew
20/02/2021 19:48 #92613 da MB RADIO
ok as you can see no entry is active. To activate it, you need to connect an audio cable to the corresponding jack
  • gandrew
20/02/2021 19:51 #92614 da gandrew
I've a cable with 2 speakers, which works !
20/02/2021 19:55 #92615 da MB RADIO
yes but you must connect something to record also
  • gandrew
20/02/2021 22:37 #92616 da gandrew
Ok I understood my mistake.
I've to loop the speaker ouput to the microphone input and in MB Recaster I select Microphone for the acquisition card.
Is it right ?
20/02/2021 23:40 - 20/02/2021 23:40 #92617 da MB RADIO
it depends on what you want to stream with MB RECASTER. If you want to stream computer audio then turn the MB RECASTER monitor card to MBRecasterMix
and choose the loopback card as capture.
If, on the other hand, you have a mixer and you want to stream the mixer audio then you have to connect the mixer output to the computer input with a cable and then select that input in MB RECASTER.
Ultima Modifica 20/02/2021 23:40 da MB RADIO.
Tempo creazione pagina: 0.071 secondi
