MBMusicReport
28/05/2019 23:54 - 29/05/2019 01:16 #87725 da Medeiros
Risposta da Medeiros al topic MBMusicReport
All three numbers are required. But here in my not the "0" (custom 2) appears as you can see in the image I sent.
I sent a file by email.
Ultima Modifica 29/05/2019 01:16 da Medeiros.
02/06/2019 11:43 #87754 da Medeiros
Did you find the problem?
02/06/2019 12:03 - 02/06/2019 12:04 #87758 da MB RADIO
Risposta da MB RADIO al topic MBMusicReport
no still not found. try to put the letter "O" instead of zero 0
Ultima Modifica 02/06/2019 12:04 da MB RADIO.
02/06/2019 13:50 #87760 da Medeiros
MB SOFT ha scritto: no still not found. try to put the letter "O" instead of zero 0
But putting "o" instead of "0" does not accept ERC. For it is a letter rather than a number.
I do not remember because it does not copy the value entered in MB Studio.
04/06/2019 18:30 #87785 da Medeiros
But why not copy.
So I do not know and it does not serve us because I need to have the three figures.
Are you still going to see if you can fix it?
Thanks
04/06/2019 19:32 #87791 da MB RADIO
yes i will try to investigate again but here is writing all the characters, nothing is missing.
13/06/2019 23:17 - 13/06/2019 23:20 #87843 da MB RADIO
After further investigation i found no problems in MB STUDIO and MBMusicReport as the .csv file generated from MBMusicReport write 045
The problem is in Excel that automtically remove the leading zero from numbers.
So you can correct this in the cell configurations, choose Personal and set three 000
Ultima Modifica 13/06/2019 23:20 da MB RADIO.
15/06/2019 19:43 #87849 da Medeiros
Yes, the problem is with Exel.
Know another program that opens the .csv file to see if it also happens the same.
What if Mbreport creates xlsv file? Also have this problem happened?
Thank you for everything and your work.
15/06/2019 20:13 - 15/06/2019 20:14 #87851 da MB RADIO
you can also use OpenOffice Calc but still you have to set the column Custom2 as Text when importing the .csv
Ultima Modifica 15/06/2019 20:14 da MB RADIO.
22/06/2019 13:39 #87910 da Medeiros
I've solved the problem.
I was not able to get the changes saved in csv but writing to xlsx gets all the info.
Thank you Maurizio. :) :)
03/08/2020 23:47 - 05/08/2020 10:30 #90968 da Medeiros
It is possible in the next update to have in MBMusicReport the option "Music activation date" in this way DD-MM-YYYY.
Thanks.
Ultima Modifica 05/08/2020 10:30 da Medeiros.
02/09/2020 00:09 #91063 da Medeiros
Medeiros ha scritto: It is possible in the next update to have in MBMusicReport the option "Music activation date" in this way DD-MM-YYYY.
Thanks.
It's possible?
Tempo creazione pagina: 0.087 secondi
