MBMusicReport
28/03/2019 18:23 #87402 da Medeiros
MBMusicReport è stato creato da Medeiros
Maurizio
For Portugal in MBMusicReport it would be possible to put the option Language, Gender, Gender2 and Gender3?
This already worked for the Portuguese Radio Law.
30/03/2019 19:41 #87445 da MB RADIO
Risposta da MB RADIO al topic MBMusicReport
31/03/2019 20:06 #87448 da Medeiros
Risposta da Medeiros al topic MBMusicReport
MB SOFT ha scritto: done www.mbradio.it/en/component/rsfiles/down...StudioInstall862.exe
:) :) Thank you very much. I'll try.
01/04/2019 10:32 #87453 da Medeiros
I installed version 8.62.2.0 but every time MBMusicReport opens this message.
01/04/2019 10:35 #87454 da MB RADIO
MB STUDIO Songs menu Save Archive
01/04/2019 18:00 #87458 da Medeiros
MB SOFT ha scritto: MB STUDIO Songs menu Save Archive
Thanks.
01/04/2019 21:47 - 01/04/2019 21:49 #87459 da Medeiros
I'm sorry, Maurizio.
I was thinking of using the genres of MBStudio to put this information into the Law and Portugal of Portuguese music.
However I had another idea that may be simpler and that does not interfere with the function of MBStudio.
It is possible to create within the "info" of the songs the options:
Nationality:
Expression:
And MBMusicReport has the option "Nationality", "Expression", "Code" (already exists in the info),
I need this information in MBMusicReport:
Time (already exists)
Duration (already exists)
Artist (already exists)
Music Name (already exists)
Nationality (create because it uses codes)
Expression (create)
Year (already exists)
Code (create)
Any questions I'm available.
Ultima Modifica 01/04/2019 21:49 da Medeiros.
01/04/2019 21:55 #87460 da MB RADIO
you can use genre2 for Nationality and genre3 for Expression
for the "code" i can add to print that value in the MusicReport.
01/04/2019 22:08 - 01/04/2019 22:18 #87461 da Medeiros
MB SOFT ha scritto: you can use genre2 for Nationality and genre3 for Expression
Yes, my idea was that. I'm just afraid that this information might later interfere with MBStudio's programming functions. So be saying to put in "Info" of songs.
I'm talking about this:
What do you say?
Ultima Modifica 01/04/2019 22:18 da Medeiros.
01/04/2019 22:28 - 01/04/2019 22:30 #87462 da MB RADIO
i think you can use genre2 and genre3 without problem to store nationality and expression.
however if you need extra fields for that you have to wait few weeks because for now i cannot modify the music database
Ultima Modifica 01/04/2019 22:30 da MB RADIO.
02/04/2019 00:19 - 02/04/2019 07:20 #87463 da Medeiros
MB SOFT ha scritto: i think you can use genre2 and genre3 without problem to store nationality and expression.
If you think there's no problem with the genres, fine. OK. I am waiting for the update of MBMusicReport with the code and insertion date of the song, to be YYYY-MM-DD (example: 2019-03-12).
Ultima Modifica 02/04/2019 07:20 da Medeiros.
02/04/2019 15:15 - 02/04/2019 15:29 #87467 da Medeiros
I think you have to use the capo "Comment" because "code" does not have to apply to multiple files.
Ultima Modifica 02/04/2019 15:29 da Medeiros.
Tempo creazione pagina: 0.106 secondi
