MB LIVE now allows you to use the remote MB STUDIO PRO instant playlist. (version .72.4.2 or higher)
At least one instant playlist must have been created and saved in MB STUDIO PRO. See here: LIVE PLAYLIST - HOW TO LOAD A JINGLES PALETTE
- click UPDATE
- select the desired instant playlist
- to play an object click on the number on the left or drag the element into the broadcast playlist (this action is denied to the guest user)
- if you wish, you can map each object to a key on the keyboard or to a MIDI note CONFIGURATION - OPTIONS - KEYBOARD
