This section is used to link some functions of MB STUDIO and/or MB LIVE with the computer keyboard, with VELLEMAN WSI8055N USB, with a MIDI device MIDI input device
- select the desired command in the list
- click inside the red box and then click the desired keyboard button or select the desired velleman bit (1 - 5) or generate the desired musical note in the MIDI device.
- click ASSIGN to save the command mapping or CLEAR to redo it.
