RDS PIRA
26/02/2009 21:27 #36326 da
RDS PIRA è stato creato da
Dear Maurizio,
i have installed a Pira RDS Coder. I can see on the radio display the text i have written in your software ( field "program servce" and "PS 2" in the folder RDS PIRA of your software ), but i can't get the song/artist information. I leave the PS 1 field blank. Is this right?
Can you tell what i'm doing wrong?
26/02/2009 23:41 #36330 da MB RADIO
Risposta da MB RADIO al topic Re: RDS PIRA
Yes, it's right to have the Dynamic PS1 label blank. MB STUDIO will fill PS! with current song/program title.
If it's not the case to you please send the debug using menu' Help/Send debug to MB SOFT
18/04/2009 10:48 #38205 da
Risposta da al topic Re: RDS PIRA
Dear Maurizio,
wii it be possible to change the way of displaying artist and title in your next update? When i use your internal program, the coder will not separate artist and title into 8 digits. Hope you understand what i mean?
19/04/2009 20:25 #38248 da MB RADIO
Dear Maurizio,
I don't think i'll be able to do so unless the PIRA encoder can do it automatically; i'll take a look to the pira documentation.
19/04/2009 23:05 #38254 da
I'm not sure, but i think with the pira software it works, so there should be a way.......
Tempo creazione pagina: 0.040 secondi
