MB Remote
09/04/2022 20:49 - 09/04/2022 20:50 #95364 da Medeiros
MB Remote è stato creato da Medeiros
Is it normal in MB Remote (1.70.3.5) for the list to be in black?
I can't get the settings predefined by me on the MB Remote in the music columns. I always have to change.
Ultima Modifica 09/04/2022 20:50 da Medeiros.
09/04/2022 20:53 #95365 da MB RADIO
Risposta da MB RADIO al topic MB Remote
the colors and settings are the same as the MB STUDIO you connect to.
09/04/2022 20:59 - 09/04/2022 21:00 #95366 da Medeiros
Risposta da Medeiros al topic MB Remote
On mine the colors don't look like it.
The photo I send now is from MBstudio.
Ultima Modifica 09/04/2022 21:00 da Medeiros.
09/04/2022 21:32 #95367 da MB RADIO
Probably the MBstudio data fodler is not c:\MBStudio but something else so MB REMOTE use the settings of that folder
www.mbradio.it/en/support/help/113-confi...onfiguration-network
10/04/2022 03:11 - 10/04/2022 03:11 #95369 da Medeiros
mine is in Z:\
Because mine is like this because it is using the server.
Ultima Modifica 10/04/2022 03:11 da Medeiros.
10/04/2022 23:11 #95375 da MB RADIO
ok, for now MB REMOTE do not support that configuration, i will look to support it as soon as possible.
11/04/2022 00:45 #95376 da Medeiros
OK. I will be waiting.
Thanks.
Tempo creazione pagina: 0.061 secondi
