UDP commands
11/11/2021 00:47 #94179 da Medeiros
UDP commands è stato creato da Medeiros
I installed version 8.69.2 and now the UDP commands from the Axel Oxygen 3000 mixer stopped working.
Everything was working fine until this version of Mbstudio was installed.
I urgently needed to know what to do as it is important for our visual radio.
11/11/2021 01:06 - 11/11/2021 01:13 #94180 da MB RADIO
Risposta da MB RADIO al topic UDP commands
Absolutely nothing has been changed.
Try to send commands with UDPClient.exe. If it works you know that nothing is wrong on MB STUDIO side
Ultima Modifica 11/11/2021 01:13 da MB RADIO.
11/11/2021 16:31 - 11/11/2021 16:34 #94198 da Medeiros
Risposta da Medeiros al topic UDP commands
UDP Client is working.
And it just stopped working after the MBStudio update.
But the port is not the same as -1 because with this -1 port it doesn't work.
Ultima Modifica 11/11/2021 16:34 da Medeiros.
11/11/2021 16:33 #94199 da MB RADIO
If UDPCLient.exe is working then MB STUDIO is ok. You must check if the IP Port and password are correct in the mixer configuration.
11/11/2021 16:41 #94200 da Medeiros
Example: I have port 92.90 in mbstudio and I use port 92.89 in the software, ie port -1 is not working
11/11/2021 17:33 - 11/11/2021 17:33 #94203 da MB RADIO
Maybe the windows firewall has blocked the UDP from another source in the LAN?
Try to send commands with UDPClient.exe from another computer.
Ultima Modifica 11/11/2021 17:33 da MB RADIO.
11/11/2021 17:45 #94206 da MB RADIO
Also check if the mixer is sending commands like explained here: www.mbradio.it/en/support/help/742-udp-api-2
11/11/2021 18:09 #94209 da Medeiros
Here it was:
12/11/2021 09:55 #94229 da MB RADIO
12/11/2021 14:10 #94238 da Medeiros
I already sent it.
12/11/2021 15:16 #94240 da MB RADIO
i replied
Tempo creazione pagina: 0.072 secondi
