My sound card doesn't appear or connection lost
  • tavocantilloh
09/09/2021 20:44 - 09/09/2021 21:13 #93676 da tavocantilloh
My sound card doesn't appear or connection lost è stato creato da tavocantilloh
When I open mb recaster Free and next plug a usb sound card this usb soundcard doesn´t appear in capture card, I have to restart mb recaster and then the usb soundcard appear.
That´s work fine in monitor audio card option.
I have installed mb recaster 5.0.1.7
En español:
Cuando abro mb recaster y luego conecto algun dispositivo de entrada como una interfaz de audio usb o una mezcladora usb, mb recaster no la detecta, no aparece en "Tarjeta de captura". Extrañamente la reconoce en "Tarjeta de Sonido Prescucha" y para que mb recaster detecte en "tarjeta de captura" debo cerrarlo y volverlo a abrir, lo cual es perjudicial ya que la transmisión se corta, y los oyentes que estén escuchando, dejan de escuchar.
De igual forma, cuando voy a desconectar mi interfaz de audio usb no desaparece de mb recaster , solo desaparece en "Tarjeta de sonido prescucha".
Ultima Modifica 09/09/2021 21:13 da tavocantilloh.
10/09/2021 13:43 #93679 da MB RADIO
Risposta da MB RADIO al topic My sound card doesn't appear or connection lost
Unfortunately MB RECASTER FREE does not detect changes in the list of sound cards (sound card added or removed). I will try to add this function in the next update.
10/09/2021 20:18 - 10/09/2021 20:18 #93698 da MB RADIO
Ultima Modifica 10/09/2021 20:18 da MB RADIO.
  • tavocantilloh
13/09/2021 16:07 #93716 da tavocantilloh
Risposta da tavocantilloh al topic My sound card doesn't appear or connection lost
Thank you very much!
