MBStudio 8.65.2.3
22/09/2020 20:02 #91195 da Medeiros
MBStudio 8.65.2.3 è stato creato da Medeiros
In version 8.65.2.3:
I detect that it does not repeat the random video file freezes when it is to repeat. And some are black.
It is possible to have the option of the music count bar with no effect at the top.
Video / hours: Font size (18) does not appear all text
Does the software not use K-Lite codecs?
22/09/2020 20:09 #91196 da MB RADIO
Risposta da MB RADIO al topic MBStudio 8.65.2.3
Medeiros ha scritto: In version 8.65.2.3:
you should send a debug every time you have a problem like this and please write the name of the file that caused the problem. Debug sent without informations are ignored.
I do not understand ..what do you mean by "music count"? please post a picture
do not understand ...please post a picture
No, VLC player has his own codecs and do not use Klite codecs
22/09/2020 21:35 - 22/09/2020 21:36 #91198 da Medeiros
Risposta da Medeiros al topic MBStudio 8.65.2.3
Option only appear texts and bar
Ultima Modifica 22/09/2020 21:36 da Medeiros.
22/09/2020 21:43 #91199 da MB RADIO
If you do not want the effects you can disable in configuration \ video \ options 3 \ Time
Yes if you have long texts and use big fonts the text will be cutted. so use small fonts and short text not so long as in your picture ...use it just for a short slogan, the song title, or telephone number.
22/09/2020 22:08 - 22/09/2020 22:10 #91201 da Medeiros
MB SOFT ha scritto: If you do not want the effects you can disable in configuration \ video \ options 3 \ Time
But disabling it eliminates the music count bar too.
Ok.
I think that the text will be very small if you reduce the font.
Before it was better
Ultima Modifica 22/09/2020 22:10 da Medeiros.
