Mbstudio restart!
07/02/2020 00:17 #89564 da Medeiros
Mbstudio restart! è stato creato da Medeiros
Hi
I notice that sometimes MB Studio shuts down and reconnects without having scheduled a software restart.
Is this normal now?
07/02/2020 00:27 #89565 da MB RADIO
Risposta da MB RADIO al topic Mbstudio restart!
It's possible this happens if the system resources goes down, the software restart to avoid a crash.
07/02/2020 00:33 - 07/02/2020 00:35 #89566 da Medeiros
Risposta da Medeiros al topic Mbstudio restart!
This is happening about 2 to 3 days.
If it does not cut the audio, it always leaves the audio at the end.
Is there another solution?
Ultima Modifica 07/02/2020 00:35 da Medeiros.
07/02/2020 00:38 #89567 da MB RADIO
Without restart the program will crash. It should be searched what is causing the low resources. Are you using OBS in the same computer? or VMix?
07/02/2020 00:41 #89568 da Medeiros
I'm using the same computer OBS.
07/02/2020 00:50 #89569 da MB RADIO
ok, if you want send a debug and i will look into it.
07/02/2020 00:52 #89570 da Medeiros
Tomorrow I send.
Thanks.
