Limit song length question
  • paul03034
25/01/2020 17:04 #89413 da paul03034
Limit song length question è stato creato da paul03034
Hello,
How can I limit any songs picked by MBStudio say 8-10 minutes before the top of the hour to say maybe no longer than 3:45 and after that restore to any length?
If it's possible to run several different limits starting at 15 minutes before hour and then 10 minutes and then 5 minutes would maybe help more where you narrow down lengths on each limit of length.
I want to get my top of the hour closer to the top and I have had songs occasionally play 3 minutes before the top that were 10 minutes long making my top of hour 7 minutes past top. I don't want to just hard limit time and it's okay to be a minute or two off. I do not like to have song start and 30 seconds later end song, so limiting song length before hand would solve issue.
Thank you for any help on this !
26/01/2020 17:13 - 26/01/2020 17:14 #89421 da MB RADIO
Risposta da MB RADIO al topic Limit song length question
Just schedule your top of hour in MB SPOT and enable the option "force" with ex: 2 minutes.
Let's see an exemple:
Here i created a break at 00:59:00 with 2 minutes of Foce Wait.
If the current song will end between 00:59:00 and 01:01:00 the "TOP OF THE HOUR" will start play normally
If at 01:01:00 the current song it's still playing MB STUDIO will fade out the current song and start playing THE TOP OF HOUR however in this case the song has already played 2 minutes
If you prefer to play a song to for a minimum of 3 minutes you can adjust the time of the break and the force value to sweet your needs.
Ex: Time Break 00:58:30 and force wait of 3 minutes.
With this system you don't have anymore too much short play of a song while keeping the break on time.
Ultima Modifica 26/01/2020 17:14 da MB RADIO.
Ringraziano per il messaggio: paul03034
