Velleman Card
  • teutoradio
26/01/2019 21:00 #87008 da teutoradio
Velleman Card è stato creato da teutoradio
Hello,
can I use also the output from the vellman card or only the inputs?
26/01/2019 23:03 #87010 da MB RADIO
Risposta da MB RADIO al topic Velleman Card
Yes you can
  • teutoradio
26/01/2019 23:21 #87011 da teutoradio
Risposta da teutoradio al topic Velleman Card
We need tor program in the folloowing way: when a special mp3 file starts everytime, at the begin of the mp3, the vellman card should send a signal output and when the mp3 ends, agian ouput signal to our mixer console. How to proogram? I only find 5 bits input, but we need to get an output signal
27/01/2019 00:40 #87012 da MB RADIO
In the properties of any item you can enable or disable the BIT 1 to 8 as you like:
  • teutoradio
27/01/2019 00:58 #87013 da teutoradio
Ok thanks, it works but only with a short bit signal, we need bit 1 the complete mp3 file on and at the end bit1 off
Possible??
27/01/2019 01:12 #87014 da MB RADIO
