MB LIVE per Android
21/01/2019 16:58 - 22/01/2019 01:53 #86936 da Medeiros
Lavori in corso: MB LIVE Android è stato creato da Medeiros
Will it be possible in the settings to have the option to enable/disable: "Keep the screen turned on"
This is so that your smartphone/tablet does not turn off the screen.
Ultima Modifica 22/01/2019 01:53 da MB RADIO.
21/01/2019 17:00 #86937 da MB RADIO
Risposta da MB RADIO al topic MB LIVE per Android
I don't know. I have to investigate and i don't know if the Android OS give me the permisison to do so.
21/01/2019 17:21 #86938 da MB RADIO
Risposta da MB RADIO al topic MB LIVE ANDROID is available for download
22/01/2019 01:15 #86947 da Medeiros
Risposta da Medeiros al topic MB LIVE per Android
Luci Android software has this option.
I think it's possible.
22/01/2019 01:53 #86948 da MB RADIO
I will add it in few days
22/01/2019 02:31 - 22/01/2019 02:32 #86949 da Medeiros
Thanks. :)
Ultima Modifica 22/01/2019 02:32 da Medeiros.
24/01/2019 11:40 #86963 da MB RADIO
25/01/2019 13:45 - 25/01/2019 13:51 #86979 da Medeiros
MB SOFT ha scritto: added on version 1.62.0.5 play.google.com/store/apps/details?id=mbsoft.mblive&hl=en
Thank you Maurizio.
I do not want to bother.
Will it be possible to create multiple configuration profiles for MB LIVE on Windows and Android?
This is so that you may have to use two or more different ips / ports / passwords and not have to always load configuration data.
Ultima Modifica 25/01/2019 13:51 da Medeiros.
25/01/2019 13:49 #86980 da MB RADIO
On windows you can already do it.
On androud i will add it
25/01/2019 13:56 #86981 da Medeiros
MB SOFT ha scritto: On windows you can already do it.
Ok...thanks.
Tempo creazione pagina: 0.072 secondi
