EXT 1-2
07/01/2019 20:14 #86834 da MB RADIO
Risposta da MB RADIO al topic EXT 1-2
to run a second istance of MB STUDIO PRO on the same computer you need a second licence loaded in the USB dongle.
You cannot plug 2 dongles at the same time
You have to install the second MB STUDIO into another folder (ex: c:\MBStudio2)
Instead of having 2 MB STUIDO PRO in a single computer if you want you can run a second computer to do the same task that i described above.
If you want to move a licence from an USB dongle to another USB dongle you can purchase the transfer service: www.mbradio.it/en/shop/services/license-...fer-or-configuration
  • teutoradio
07/01/2019 20:27 #86835 da teutoradio
Risposta da teutoradio al topic EXT 1-2
Can this be done online or do I have to wait for a new dongle by post ?
07/01/2019 20:33 #86836 da MB RADIO
I assume you already have 2 usb dongles with 1 license MB STUDIO PRO each. So you will receive instrucions by email to move the license from dongle 2 to dongle 1. At the end of operation you will have 2 MB STUDIO PRO licences on dongle 1 and 0 licenses on dongle 2 (will be empty)
  • teutoradio
07/01/2019 21:24 #86837 da teutoradio
Yes no problem, we have more than one dongle in your radio station. I send you the order, waiting for your instructions.
  • teutoradio
08/01/2019 12:36 #86840 da teutoradio
Dear Mautizio,
is there a description how to program tboth instances o one pc.
I'm not sure where to put in the ip and or what port?
08/01/2019 16:44 #86841 da MB RADIO
in setup \ netowrk you'll see the port number where MB STUDIO wait connections
in the same window you'll see the "Remote host" box: here you write localhost:port (port is the port number of the MB STUDIO to send commands, so the other MB STUDIO)
so if MB STUDIO 1 is waiting connections on port 9210 and MB STUDIO 2 is waiting connections on port 9432 the box "Remote Host" would be "localhost:9432" on MB STUDIO1 and "localhost:9210" on MB STUDIO2
  • teutoradio
08/01/2019 17:54 #86842 da teutoradio
Ok, it works but only in one direction, if I plan a delay on the second MB Studio 2 will be go on air EX1 but if i skip on MB Studio 2 the EX1, on MB Studio 1 will not be start the next title in the list.
08/01/2019 18:51 #86843 da MB RADIO
You don't need to play anything on MB STUDIO 2 just keep it on PLAY ALL with the playlist empty.
  • teutoradio
08/01/2019 22:44 #86847 da teutoradio
OK, but if the EXT Stream produce silence, the silence detector should start the next song in MB Studio 1 should start, but it dosen't
What can i do to fix it?
08/01/2019 23:00 - 08/01/2019 23:01 #86849 da MB RADIO
teutoradio ha scritto: OK, but if the EXT Stream produce silence, the silence detector should start the next song in MB Studio 1 should start, but it dosen't
Check again that you made all the settings that i showed you otherwise i will do it for you
Ultima Modifica 08/01/2019 23:01 da MB RADIO.
  • teutoradio
09/01/2019 00:09 #86851 da teutoradio
Should I send you a debug?
09/01/2019 00:17 - 09/01/2019 00:17 #86852 da MB RADIO
Select menu help \ connect MB SOFT and send me privately the id and password. i will connect to your computer and i will do the right configuration
Ultima Modifica 09/01/2019 00:17 da MB RADIO.
Tempo creazione pagina: 0.069 secondi
