Commercial
  • teutoradio
23/09/2018 19:29 #86071 da teutoradio
Commercial è stato creato da teutoradio
Is there a way, to finish a commercial block at a specific time? Normally, i program the commercials to start for example at 0:55. So in this way, the commercials block ends, depending on the total time
sometimes at 0:57 or sometimes later ( depends on the total numbers of spots )
I need the commercial block finished on a fixed end time, for example :00, to start the news exactly at :00 right after the spots. In this way, the commercial will start on different times, but will be finished at the exact programmed time.
Is there a solution?
23/09/2018 20:25 - 23/09/2018 20:26 #86072 da MB RADIO
Risposta da MB RADIO al topic Commercial
Yes, just enable the "Force" option and Enable the option "Finish at"
in this case the time of the break is not the starting time but the finishing time.
Also remember that you cannot have 2 breaks having the same time, so if you have the following break starting at 04:00:00 you must set the "finish" time of this break 1 second before so 03:59:59
Please note that type of break ("Finish at...") only work if you have static items inside the break, while it do not work if you have variable items like random files, external streams, random songs, etc etc)
Ultima Modifica 23/09/2018 20:26 da MB RADIO.
Tempo creazione pagina: 0.035 secondi
