MB Recaster Free - Buffer settings
  • GTHvidsten
06/09/2018 12:45 #85926 da GTHvidsten
MB Recaster Free - Buffer settings è stato creato da GTHvidsten
I'm noticing my players are getting buffer underruns when playing a stream supplied by MB Recaster. I can temporailly fix the audio skips by increasing the buffers in the players, but this only delays the issue as the audio skips will still appear, it just takes longer for them to do so.
I've looked around in the settings for MB Recaster but I haven't been able to find any specific buffer settings. Are there any such options, or do I just have to live with the skipping?
(It is not a network or client issue. I used to use SAM Broadcaster and never had any problems with buffer underruns.)
06/09/2018 13:54 #85929 da MB RADIO
Risposta da MB RADIO al topic MB Recaster Free - Buffer settings
A Shoutcast or IceCast source client application has no network buffer involved, the buffer is in the server so you should check your stream server settings for the buffer available to the clients.
  • GTHvidsten
23/10/2018 20:40 #86347 da GTHvidsten
Risposta da GTHvidsten al topic MB Recaster Free - Buffer settings
I never got rid of these buffering issues and finally did some troubleshooting. My conclusion is, unfortunately, that MBRecaster is the culprit.
I tried switching between different versions of shoutcast and icecast, and they all had problems.
The buffering issues appeared even when connected to the same network switch as the server (so there should be no delays) which rules out ISP issues.
When listening to the actual soundcard output there were no skips.
I went back to SAM Broadcaster and I've been listening for a long while now without any buffering issues.
My only conclusion can then be that this must be an MBRecaster issue.
Unfortunately, upgrading to the latest version is a no-go as this does not support higher bitrates than 192kbps.
I like what I've seen from MBRecaster so far, so what can I do to help?
23/10/2018 21:28 - 23/10/2018 21:30 #86348 da MB RADIO
Which version of MB RECASTER are you using? and which player are you using to listen the stream? what i have to do to reproduce the same probleme here? are you using the "limit rate" option?
Ultima Modifica 23/10/2018 21:30 da MB RADIO.
  • GTHvidsten
23/10/2018 21:32 #86349 da GTHvidsten
Version 4.5.3.1.
Buffering occured in Winamp, VLC, and on the built in player on my Denon surround receiver.
Windows Server 2016 with Realtek audio drivers.
23/10/2018 21:34 #86350 da MB RADIO
Which codec? mp3? how much bitrate? limit rate is enabled?
  • GTHvidsten
23/10/2018 21:47 #86351 da GTHvidsten
Buffering with both MP3 and AAC.
Tested with bitrates of 320, 256 and 192 kbps.
"Limit rate" was always off
23/10/2018 21:57 - 23/10/2018 21:57 #86352 da MB RADIO
a last question: how much time elapse before buffer underrun is audible?
Ultima Modifica 23/10/2018 21:57 da MB RADIO.
  • GTHvidsten
23/10/2018 22:00 #86353 da GTHvidsten
320kbps was usually audible after roughly 15 minutes (same for AAC and MP3).
After the first buffer underrun it continued roughly every 2-3 minutes.
256kbps had the first underun after roughly 25 minutes.
23/10/2018 22:10 #86354 da MB RADIO
ok i will now listen this test stream for next couple of hours 178.32.136.9:9033/stream
Tempo creazione pagina: 0.090 secondi
