MB Studio strange thing
  • paul03034
01/07/2017 16:40 #83266 da paul03034
MB Studio strange thing è stato creato da paul03034
Hello,
I had MB Studio playing ever so happy and then I noticed that when time announcement came it said "it is 12 ..........................4 second delay ................15 and then silence and 5 seconds later song. Sometimes songs played back to back and other times long pause between.
Apparently the reason was the RDS serial port was disconnected and enabled in program.
Just wanted to point it out. I did re-start program and problem went away and later came back.
I thought it used to give message of unable to connect. Only Velleman gives unable to connect
Once I connected RDS everything went back to normal.
A notice if while running would have been nice as I would have known the issue was a connection. Probably does not operate bidirectional on RDS? Not big issue just mentioning it.
Thank you!
01/07/2017 18:18 #83273 da MB RADIO
Risposta da MB RADIO al topic MB Studio strange thing
I dont' know what coudl be the cause of it, if you want send the debug for investigate it.
