Cueing points in mp3
  • teutoradio
07/06/2017 14:39 #82967 da teutoradio
Cueing points in mp3 è stato creato da teutoradio
When I label an mp3 with MB Studio, the information ( Start, Intro, Teaser In, Teaser out, Outro and stop will be saved in the IDTag of the mp3 or in an extra database of MB Studio?
07/06/2017 15:05 - 07/06/2017 15:08 #82968 da MB RADIO
Risposta da MB RADIO al topic Cueing points in mp3
both in the file and in the database.
if you loose the database you'll retrieve the data from the audio file
if you loose the tag you still have the data in the database (use menu' Edit \ Write Tag to rewrite tag to one, some or all songs)
Ultima Modifica 07/06/2017 15:08 da MB RADIO.
  • teutoradio
07/06/2017 15:52 #82969 da teutoradio
Risposta da teutoradio al topic Cueing points in mp3
Where can i find the database ( name of the file ) ?
07/06/2017 16:19 #82970 da MB RADIO
MBSongs.dat
  • teutoradio
08/06/2017 22:30 #82985 da teutoradio
OK thanks!
What kind of database do you use? We have the problem, that we send sometimes some mp3 from the our MB Radio Automation to a partner radio station who use another system but the cant read the cueing points.
Is there a way to convert?
08/06/2017 22:38 #82986 da MB RADIO
Unfortunately there is not a standard to exchange cue point between different applications
