Recaster Pro & MB Spot ?
  • paul03034
06/06/2017 15:39 - 06/06/2017 15:44 #82955 da paul03034
Recaster Pro & MB Spot ? è stato creato da paul03034
Hello,
I schedule a .wav mono recording in Recaster Pro and MB Studio and Recaster audio editor throw an error message.
Windows Media player will not play recorded file either
File exists but seems to maybe be encoded incorrectly?
Needless to say, my show recordings don't play.
Ultima Modifica 06/06/2017 15:44 da paul03034.
06/06/2017 16:08 #82958 da MB RADIO
Risposta da MB RADIO al topic Recaster Pro & MB Spot ?
wav files has a time length limitation ...how many hours you recorded the file?
  • paul03034
06/06/2017 17:39 #82961 da paul03034
Risposta da paul03034 al topic Recaster Pro & MB Spot ?
59 minutes total 297 MB file
Timer starts at 8:00 and stops at 8:58 which works out to 59 minute recording.
Media player reports
I'll try a different record on the fly and see what happens and let you know.
06/06/2017 17:42 - 06/06/2017 17:43 #82962 da MB RADIO
1 hour record should not be a problem ..maybe the file recording prematurely stopped due to a technical problem?
Ultima Modifica 06/06/2017 17:43 da MB RADIO.
  • paul03034
06/06/2017 18:12 #82963 da paul03034
Not that I am aware of, but I won't rule it out.
Its the first time I tried to air a record and assumed it was OK. It could be a freak incident.
Good thing was MB Studio just moved along and started playing music in its place.:>)
I am doing a 1 hour record now using wave stereo and mp3. If it is OK it was technical glitch otherwise I will report back if it fails.
I'll do several today and make sure it is truly OK.
Thank you!
06/06/2017 18:16 - 06/06/2017 18:17 #82964 da MB RADIO
when you can, select the menu MB RECASTER \ Help \ Send debug i would take a look to the logs to see if i remark the cause of the problem
Ultima Modifica 06/06/2017 18:17 da MB RADIO.
  • paul03034
06/06/2017 23:50 #82965 da paul03034
Ok will do, but I think I know what did happen already.
MB Recaster accidentally got launched while the other was open and recording.
I had a quick launch of Recaster and I think the mouse accidentally clicked on quick launch bar where recaster was. It is removed now, so that can't happen again.
I played on another computer and found if you launch it while the other is open, it duplicates/mirrors the open recaster and corrupts the recorded file.
It is hard to catch but Recaster opens for a second and closes.
That's my guess, but it will be good to know for sure.
Thank you!
06/06/2017 23:54 #82966 da MB RADIO
ok thanks for the report ...i will check about it
13/06/2017 23:59 #83030 da MB RADIO
paul03034 ha scritto: Ok will do, but I think I know what did happen already.
You was right ... if MB RECASTER PRO runs twice it can cause corrupted records ...it's now fixed in version 4.2.3.
Tempo creazione pagina: 0.079 secondi
