MB Recaster record timing issue
  • paul03034
30/05/2017 15:10 - 30/05/2017 15:14 #82879 da paul03034
MB Recaster record timing issue è stato creato da paul03034
Hello,
If I set a record for 8:00 it starts correctly, about a second before GOOD
I set a stop time of 8:59 and it continues recording to 8:59:59 which is 59 seconds past stop time Bad
It never seems to end at any stop time correctly.
I'm trying 9:30 - 9:58 to see if it goes past time and will update this post then.
Ultima Modifica 30/05/2017 15:14 da paul03034.
30/05/2017 16:28 #82883 da MB RADIO
Risposta da MB RADIO al topic MB Recaster record timing issue
the STOP time is inclusive, it means that the it will stop just at the end of minute 59. If you want to stop at 59:00 set the stop time at 58
  • paul03034
30/05/2017 16:59 - 30/05/2017 17:00 #82885 da paul03034
Risposta da paul03034 al topic MB Recaster record timing issue
Just discovered that on :58 stop time.
Do you think you will ever be able to add the VOX function like in MB Spot to ReCaster Pro?
Thank You!
Ultima Modifica 30/05/2017 17:00 da paul03034.
30/05/2017 17:19 - 30/05/2017 17:21 #82887 da MB RADIO
paul03034 ha scritto: Just discovered that on :58 stop time.
Yes i will add it in the near future
Ultima Modifica 30/05/2017 17:21 da MB RADIO.
Ringraziano per il messaggio: paul03034
  • paul03034
01/06/2017 00:25 #82919 da paul03034
Excellent and Thank You!
