Song Infos
  • teutoradio
20/05/2017 10:13 #82743 da teutoradio
Song Infos è stato creato da teutoradio
Hello!
Is it possible to display on internet steam for for example a special show no song title, but only the name of the show?
20/05/2017 12:00 - 20/05/2017 12:01 #82747 da MB RADIO
Risposta da MB RADIO al topic Song Infos
Yes, see here: www.mbradio.it/en/help/472-caratteri-jolly-per-esportazione-2 ...if you need to change the setting only for a show use Agenda - Internal Command to change and / or restore that setting
Ultima Modifica 20/05/2017 12:01 da MB RADIO.
  • teutoradio
20/05/2017 12:23 #82749 da teutoradio
Risposta da teutoradio al topic Song Infos
You mean:
Agenda - Internal command - textonair.txt - %nosongs% ( in the optional parameter ) ???
20/05/2017 12:34 #82750 da MB RADIO
yes
  • teutoradio
04/06/2017 11:48 #82942 da teutoradio
How can I activate the song display again?
  • paul03034
05/06/2017 19:13 - 05/06/2017 19:13 #82946 da paul03034
Risposta da paul03034 al topic Song Infos
I would guess in Agenda - Internal Command - Metadata Text (when you want your song metadata to return).
Just a guess and I hope that's the answer to your question!
Ultima Modifica 05/06/2017 19:13 da paul03034.
06/06/2017 13:35 #82948 da MB RADIO
teutoradio ha scritto: How can I activate the song display again?
Agenda - Internal command - textonair.txt - (leave empty the parameter field)
