Minilist and audio file
  • paul03034
15/05/2017 02:24 #82616 da paul03034
Minilist and audio file è stato creato da paul03034
Hello,
I noticed that when I create a minilist the one thing with an audio file is even after changing audio file from standard mix to no mix it always reverts back to standard mix after saving. Some audio files in a minilist I might want a standard mix and others no mix and I can never save it like it does in regular playlists.
Suggestion of what I am doing wrong or is this a bug?
Thank you!
15/05/2017 02:40 #82617 da MB RADIO
Risposta da MB RADIO al topic Minilist and audio file
I was unable to reproduce the problem here, i set "No Mix" to 2 files in a minilist and the property is still there after saving or even when minilist is on air
  • paul03034
15/05/2017 02:43 - 15/05/2017 02:55 #82620 da paul03034
Risposta da paul03034 al topic Minilist and audio file
This only applies to minilist
I go and it is standard mix
[attachment:1]minilist 1.jpg[/attachment
I change to no mix and apply
I look at properties and it says standard mix
Ultima Modifica 15/05/2017 02:55 da paul03034.
  • paul03034
15/05/2017 13:45 #82629 da paul03034
Here is the minilist that was set to no mix in the playlist.
I do not see anything saying no mix where it is inserted from minilist.
Playlist is fine and stores settings.
15/05/2017 17:11 #82631 da MB RADIO
fixed on version 8.59.1.1
Ringraziano per il messaggio: paul03034
