Recaster Pro streaming details
  • paul03034
12/05/2017 14:54 #82596 da paul03034
Recaster Pro streaming details è stato creato da paul03034
Hello,
How do you change the stream details as I fill in everything needed, but when I search icecast directory my details do not show unless I search MB Studio, then I see my stream details.
In MB Studio Pro, it is not an issue using built in streaming and I think my settings are the same.
Thank you!
12/05/2017 14:59 #82597 da MB RADIO
Risposta da MB RADIO al topic Recaster Pro streaming details
You should fill in all the fields (Except for Text)
  • paul03034
12/05/2017 18:57 - 12/05/2017 19:06 #82604 da paul03034
Risposta da paul03034 al topic Recaster Pro streaming details
I have it set that way, but it comes up with MB Recaster in title
Also there are two streams and the second doesn't show while using MB Studio Pro it does
MB Studio Pro's encoders show up all streams and details for each.
The two streams are available and artist and title are passing to the server.
If I search MB Recaster both streams show under that search
Normally it just say WQNH
Ultima Modifica 12/05/2017 19:06 da paul03034.
12/05/2017 23:32 #82606 da MB RADIO
Is your MB RECASTER running in licensed mode or demo mode? In demo mode MB RECASTER overwrite the metadata with "MB RECASTER " string.
Look at menu MBRecaster \ About ... check if it's MB RECASTER PRO or MB RECASTER Demo
  • paul03034
13/05/2017 03:45 - 13/05/2017 03:47 #82609 da paul03034
Yes it is running Licensed.
If you left either field empty it put in MB Recaster.
Putting Text in both fields took care of the issue
Ultima Modifica 13/05/2017 03:47 da paul03034.
