add folders problem
  • radio7
21/02/2017 12:08 #81901 da radio7
add folders problem è stato creato da radio7
Hello.
MB studio in older versions at once knew add folders automatically (MBStudio / Setup / Folders / Add), only always ask yes / no to a specific folder (or add him or not). Now it's time consuming and the possibility that a folder is not added.
Thanks.
21/02/2017 12:20 #81902 da MB RADIO
Risposta da MB RADIO al topic add folders problem
You don't need anymore to add subfolders ..see here: www.mbradio.it/en/help/462-setup-folders
  • radio7
21/02/2017 14:02 #81904 da radio7
Risposta da radio7 al topic add folders problem
But MB studio don't work this way. I know, what you mean by "don't need anymore to add subfolders" but MB Studio still doesn't see it. For example: I have folder named "Y", and "Y" has 45 subfolders. In version 8.56.2 MB studio knew add all subfolders by clicking Yes (45 subfolders). In actual version 8.58.0.5 it doesn't know do it this way. I have to add each subfolder individually. I have: Error File - unable to load: KAIROS.mp3 ... So MB studio doesn't know load .mp3 files in my subfolders. Can you know fix this problem?
21/02/2017 14:15 - 21/02/2017 14:16 #81905 da MB RADIO
No, you don't need to add all the subfolders anymore, once MB STUDIO need to play a file it will serch it automatically inside all your 45 subfolders and when found it will add the subfolders to the folders list. This happen automatically in the background so you don't need to add all the subfolders to the window.
If this is not happenng to you use menu help \ Send debug to investigate your problem or try to use the very latest version 8.56.0.8 (maybe there is a bug in the .5 version)
Ultima Modifica 21/02/2017 14:16 da MB RADIO.
  • radio7
22/02/2017 15:45 #81910 da radio7
I tried it on another PC and it works well. I'll try to reinstall my mb studio.
Thanks.
