Rotation and live playlist
14/06/2015 17:57 - 15/06/2015 14:27 #77892 da radiop
Rotation and live playlist è stato creato da radiop
Good afternoon, use the Mbstudio some years, much like the software. The only problem I can not solve and that bothers me is the fact repeat the songs. His tendency is to put the same songs more or less the same times. Even with the option of not repeating the same singer in space 3, 4, hours .... he does not respect the criteria. You lose a lot of the songs in the rotation. I wonder with the best setting to prevent this from happening? Another very negative aspect and that does not happen in most of the software is not having in-built the live playlist. Ie instead of opening side must be fixed on the couch, not all radios use two waxes. Sending a photo as an example that should follow. is very stressful to be always open and close, users do not like. On top there is a space mbstudio which is empty on the screen.
Thank you.
Ultima Modifica 15/06/2015 14:27 da radiop.
14/06/2015 18:05 - 14/06/2015 18:11 #77893 da MB RADIO
Risposta da MB RADIO al topic Rotation and live playlist
For the rotation problems you must select menu Help / Send debug and specify at least one title that has not respected the rule. I cannot help you without see the database.
In your pictures it seems you're not playing songs from the archive but files from the disk. The rotation has no effect on files. You must load the songs in the database and the insert a Random Song in teh playlist if you want the rotation rules has effect. See here: www.mbradio.it/en/help/310-songs-how-to-...songs-to-the-library and here www.mbradio.it/en/help/304-playlist-the-first-playlist
As for the live playlist suggestion there is a new MB STUDIO upcoming in the next weeks that will solve your problem.
Ultima Modifica 14/06/2015 18:11 da MB RADIO.
14/06/2015 18:20 #77895 da radiop
Risposta da radiop al topic Rotation and live playlist
I'm glad for the change, from what I saw I liked! Thanks for the answer. Tomorrow send debug. You can send me the correct settings of the songs?
Thank you.
14/06/2015 19:01 #77897 da radiop
The songs that were included were from out of libraria is a demo version of mbsudio a laptop, it is not the pc studio. yes this is all in libraria. Thank you.
