Rotatividade 2
30/11/2014 17:52 #75870 da radiop
Rotatividade 2 è stato creato da radiop
Good afternoon,
I am from Portugal.
I already have some years MBSTUDIO PRO is a fantastic software.
Just have a problem I can not solve in any way, I saw here in the forum there are radios with the same problem.
In terms of turnover the MBSTUDIO failure, that is very repeats the songs.
Even with many songs he plays many repeated and often at the same times. In radio terms is a serious problem because it gets very repetitive.
I wish I had help.
Thank you
30/11/2014 17:59 #75872 da MB RADIO
Risposta da MB RADIO al topic Re:Rotatividade 2
Which version of MB STUDIO are you using?
30/11/2014 19:21 #75873 da radiop
Risposta da radiop al topic Re:Rotatividade 2
  8.55.3
30/11/2014 21:24 #75876 da MB RADIO
I'm aware there is a problem that will be fixed in the upcoming update
30/11/2014 21:32 #75878 da radiop
Would that help me to how best "general configuration in music" MBSTUDIO and how best rotation only in each of the songs?
Thank you very much.
30/11/2014 22:18 #75879 da MB RADIO
You can start with this setup\songs:
Distance among same Artist 2 hours
Distance among same Title 0 hours
Distance among same Album 0 hours
Distance among same Hitlist 1 hour
do not set custom setup on the songs and let MB STUDIO to freely rotate it.
30/11/2014 22:21 #75880 da radiop
Thank you very much!!!
  • greatwindowsss
17/01/2015 05:55 #76217 da greatwindowsss
Risposta da greatwindowsss al topic Rotatividade 2
My question is very simply, how to change the english language to spanish?
Thanks!
17/01/2015 14:41 #76218 da MB RADIO
Risposta da MB RADIO al topic Rotatividade 2
Normally it display the same language of your Windows operating system.
However if you want to force a different language, explore the subfolder Language, rename English.lng to something else, and rename Spanish.lng to english.lng and restart the application.
Tempo creazione pagina: 0.061 secondi
