MB STUDIO 8.51
02/10/2012 12:04 - 02/10/2012 12:22 #65887 da MB RADIO
MB STUDIO 8.51 è stato creato da MB RADIO
update MB STUDIO version 8.51
A new version of MB STUDIO 8.51 is now available on the customers area
Changes list compared from previous version
  • On the main screen changed positions of some buttons.
    The "Messages Centre" button has been moved under the "Messages" tab:
    MB SPOT button is now located to the right of the cover image:
    The Agenda button has been removed, and you can enter the Agenda windows using menu Tools:
  • Shoutcast 2 compatible
  • autoresize covers
  • up to 10 MB STUDIO can run on the same computer (require a corresponding number of licenses into the cryptobox usb)
  • audio codec and runtime updated to the latest versions
  • less cpu load
  • few bugs fix
NOTICE:
  • This updated is intended for MB STUDIO 8.50 users. To run the updater use the same password supplied for the 8.50 update.
    If you're still using an older version of MB STUDIO (8.46 and lower) send an email with your license number to receive instructions for updating to 8.50
  • After installing MB STUDIO 8.51 a fine tuning of Setup\Audio\Crossfade\Standard Mix could be required; due to a bug in MB STUDIO 8.50 that value was applied twice. Ex: 0,1 was applied 0,2; 0,2 was applied 0.4; so after installing MB STUDIO 8.51 you can increase twice the parameter (ex: increase from 0,1 to 0,2). No changes are required if you was using 0.
Ultima Modifica 02/10/2012 12:22 da .
