ALWAYS RUN MB STUDIO AS ADMINISTRATOR
09/05/2012 15:17 #64499 da MB RADIO
ALWAYS RUN MB STUDIO AS ADMINISTRATOR è stato creato da MB RADIO
I advise you to set all MB STUDIO executable files with “Administrator” privilege. This will allow MB STUDIO to read/write the Windows registry for configuration purpose (“Run with windows”) or for registering components (Tortuga.dll e Abalezip.dll). To set “Administrator” privilege browse the MBStudio folder and right click MBStudio.exe, MBstudioLan.exe, MBStudioDemo.exe, MBSpot.exe files, select Properties \ Compatibility and activate the option to run the program as administrator.
Right click: Properties
Click on "Run as administrator"
10/07/2013 01:45 #70917 da MB RADIO
Risposta da MB RADIO al topic disable UAC (User Account Control)
you are required to disable UAC (User Account Control) to run MB STUDIO without troubles
see here how to disable UAC:
support.kaspersky.com/8210
