MB LIVE periferique
18/07/2011 18:12 #58022 da
MB LIVE periferique è stato creato da
Hi,
I use MB LIVE 1.46 on a PC with XP SP2, connection and use is OK on the PC with MB STUDIO 8.46 which means MBSTUDIO configuration seems good. But now I have a new PC on WINDOWS 7 64b, I can install MB LIVE 8.46, software is running but periferique area is empty, no sound card detected ? I have tried with another PC on WIN 7 64b and the same result. Please why ?
When I try the button CONNECT, connection start but stop immediately with a message error "absence de son en entrée".
18/07/2011 18:15 #58024 da MB RADIO
Risposta da MB RADIO al topic Re: MB LIVE periferique
In MBLive\Debug folder there is Monday file...please send it to see your configuration.
18/07/2011 18:34 #58025 da
Risposta da al topic Re: MB LIVE periferique
File is on the mail
18/07/2011 18:34 #58026 da MB RADIO
According to debug file there are no capture WDM audio cards available in the system.
Please check this window if there are audio cards available.
19/07/2011 07:50 #58042 da
Yes there is an integrated audio card on the mother card. This is a PACKARD BELL
19/07/2011 10:23 #58048 da MB RADIO
As you see there is nothing connected, "Non connecté".
In windows 7 and Vista, some cards only work when you phisically attach a plug to the input. So, first connect a cable to the jack input, after run MB LIVE and you'll get the program to work.
19/07/2011 18:53 #58071 da
You're. It's OK now with a cable connected on the audio card.
Thank you very much. I didn't know this approach !!
See you
