Streming MB Studio
13/04/2010 00:39 #47153 da Medeiros
Streming MB Studio è stato creato da Medeiros
Maurizio I am to use streming in the MBStudio and for times it appears the window of the DOWS and appears this information in log.
Because this appears and as I make not to appear?
13/04/2010 02:01 - 13/04/2010 02:03 #47154 da MB RADIO
Risposta da MB RADIO al topic Re: Streming MB Studio
In Configuration\WebCast\More you have this option enabled "In case of failure network test", so MB STUDIO run the dos commands "ping" and "tracert" to test if your destinations are reachable (while ping and tracert are running you'll see black dos windows for few seconds).
In the folder LogWebCast you'll find the results of ping and tracert; here you'll find help to understanding the problems of your network.
As you can see, at 20:26:28 you was experiencing a packet loss problem:
A rastrear a rota para apollo.redelx.com [77.91.203.179] at‚ um m ximo de 30 saltos:
 1    <1 ms    <1 ms    <1 ms  192.168.1.1
 2   698 ms   629 ms     *     10.5.0.1
 3   705 ms     *      838 ms  pa1-84-91-0-89.netvisao.pt [84.91.0.89]
4     *        *        *     O pedido excedeu o tempo.
 5     *      982 ms     *     apollo.redelx.com [77.91.203.179]
 6   462 ms   471 ms   486 ms  apollo.redelx.com [77.91.203.179]
Rastreio conclu¡do.
Ultima Modifica 13/04/2010 02:03 da .
13/04/2010 11:54 - 13/04/2010 11:56 #47166 da Medeiros
Risposta da Medeiros al topic Re: Streming MB Studio
Not to appear black dos windows for few seconds disablbe option "In case of failure network test"?
Ultima Modifica 13/04/2010 11:56 da .
13/04/2010 12:17 #47167 da MB RADIO
If you disable that option you&#039;ll never see black windows, but also you&#039;ll never get the ping and tracert file reports, so, in case of network problems, you&#039;ll never know where is the problem ... it&#039;s your choice.
13/04/2010 12:43 #47169 da Medeiros
Maurizio thanks!!
