MB STUDIO UPDATE 8.42
07/03/2010 05:39 - 07/03/2010 05:47 #46344 da MB RADIO
MB STUDIO UPDATE 8.42 è stato creato da MB RADIO
MB STUDIO version 8.42
This update fix all the latest problems reported after version 8.41
  • Songs: rotation bug, some songs was not playing from a "Random Song" item
  • Random commercials, sometimes Random Spots was not playing
  • MB SPOT: in the customer Items List you can now add multiple times the same file with different calendars
  • Webcast: the Start/Stop button and audio input level was moved in Configuration \ Webcast
  • Live Playlist: fixed a problem when overlapping an item
  • External titles: fixed a "Wrong password" message
  • MB LIVE: you can now set and play a liner before and after MB LIVE item
  • Audio Win 7: in case of faulty audio driver and "Stream stalled" message, MB STUDIO try to reinitialize the audio card
WARNING:
  • Before to update MB STUDIO, make a backup copy of the MBStudio folder; if you have problems with the new version, simply restore the previous MBStudio folder
  • When using MB STUDIO over multiple computers, first update the ON AIR computer and immediately all other computers. don't use mixed versions of MB STUDIO due possible incompatibilities.
  • This version of MB STUDIO require MB LIVE 1.42 (if you use it). Previous versions of MB LIVE could not work properly.
To download MB STUDIO 8.42 login into customer area www.mbradio.it/en/ftp-utenti , download and run the file MBStudioUpdate842.exe
Ultima Modifica 07/03/2010 05:47 da .
Tempo creazione pagina: 0.038 secondi
