PlayList.txt
21/10/2009 23:04 #42634 da
PlayList.txt è stato creato da
Dear Maurizio!
I have the problem, that the "PlayList.txt" file in the MBSoft folder will not be new overwritten.  Do you know what to do?
Best Regards
Andreas ???
22/10/2009 00:40 - 22/10/2009 00:43 #42635 da MB RADIO
Risposta da MB RADIO al topic Re: PlayList.txt
The old playlist.txt is no more featured in MB STUDIO 8.35 because there are more advanced features available. However to immediately reactivate the old functionality, put the attached playlist.txt file anywhere in your computer and configure it like this:
You can change the text in anyway you like. Full jolly characters list:
%timexx%  - the clock of the broadcasted or scheduled item
%itemxx% - the item title
%yearxx%
%commentxx%
%albumxx%
%authorxx%
%labelxx%
%codexx%
%filexx% - display the filename instead of the program name
Note: xx means a number from 0 (the current on air item) to 99
If you want to display brodcasted items (instead of the scheduled items) just use negative number (ex %item-1% will display the last brodcasted item)
Ultima Modifica 22/10/2009 00:43 da .
22/10/2009 10:04 #42637 da
Risposta da al topic Re: PlayList.txt
Hi!
Thanks for your reply. can you tell me also what to change in the last.txt file?
Best Regards
Andreas
22/10/2009 14:09 #42646 da MB RADIO
what is the "last.txt" file?
Tempo creazione pagina: 0.037 secondi
