Problemi con la scheda M-Audio Delta 66, l'audio frigge.
09/09/2011 18:06 #58725 da RADIO FORMAT
grazie Radio Incontro. Noi non usiamo "ASIO" e sono indecisa se reinstallare quel driver ancor di più dopo essere andata sul forum di M-AUDIO e letto questa risposta forums.m-audio.com/showthread.php?30847-...ver+5.10.00.5076+sp3
The settings on the mixer tab control the Delta's monitor mixer, and for this to have an audible effect, you need to assign the Monitor Mixer as the output source on the Patchbay/Router or Output Tab, depending on which driver version you're running. If you're on XP, I would suggest using driver 5057v3 with the old control panel style.
gianluigi petruccio
12/09/2011 16:15 #58743 da MB RADIO
L'unico driver stabile è l'ultimo (5076) e cioe' questo:
www.m-audio.com/index.php?do=support.drivers&f=1171&dl=yes
12/09/2011 17:41 - 12/09/2011 17:43 #58745 da Radio Incontro
Anche se con Windows XP SP3, il driver navigator di M-Audio indica come unico disponibile proprio quello in tuo possesso cioè il 5057.
Ultima Modifica 12/09/2011 17:43 da .
12/09/2011 18:10 #58748 da MB RADIO
Fonte M-AUDIO:
Applies to: Delta 44, 66 (OmniStudio), 410, 1010, 1010lt, Audiophile 24/96 & 192 devices.
Operating Systems Supported:
(32-Bit) XP SP3, Vista SP2, Windows 7
(64-Bit) Vista SP2, Windows 7
Our latest Windows Delta driver release (Installer Package 6.0.5 with Driver 5.10.00.5076) was posted to solve a compatibility problem with newer series motherboard chipset and CPU combinations from Intel. The problem identified was a low level distorted audio occuring with Core2Duo and i-Series processors. The sound in question resembled bacon sizzling while. Despite this one fix, we here in the Test and Customer Support groups stressed pretty heavily over whether or not to release this driver to full release knowing that there are other outstanding issues with the driver.
We felt that the severity of the issue was great enough to push this to full release for those users wishing to use the card in newer system configurations. The outstanding issues already identified by our customers are still being considered for possible future releases.
We encourage you to download and use this new driver and continue to provide us feedback on your experiences with this driver over the previous releases.
30/04/2014 18:59 #74561 da Radio Incontro
La frittura però, a quanto pare, continua..  :(
Tempo creazione pagina: 0.041 secondi
