The Chilkat error means that it was not possible to register the ChilkatAx-win32.dll library in Windows which is essential for the functioning of MB STUDIO, MB REMOTE, MB LIVE.
It is possible that a protection or limitation is active in your Windows that prevents the automatic registration of the component and you must therefore proceed manually.
Here are some operations to try before resorting to our technical assistance:
REINSTALL MB STUDIO
Download MB STUDIO from here: https://www.mbradio.it/en/download-en/customers-area?folder=MB_STUDIO and reinstall it. Once finished, restart Windows.
If this solution does not solve the problem, proceed to the next solution.
MANUAL REINSTALLATION OF CHILKAT
Close all MB STUDIO, MB SPOT, MB REMOTE, and any other MB RADIO software sessions.
Open the Windows command prompt in administrator mode
| WINDOWS 10 | WINDOWS 11 |
and then write
regsvr32 /u c:\mbstudio\ChilkatAx-win32.dll and hit enter
and then write again
regsvr32 c:\mbstudio\ChilkatAx-win32.dll and hit enter
If successful you will see this message:
