Webcam
20 Sep 2019 20:19 #88426 by Medeiros
Webcam was created by Medeiros
I installed a webcam (Logitech hd pro webcam c920) so it can be used when the microphone is open.
Connect to a sound card (EXT 1) that is only activated with voice.
But how does the camera turn on and in the image? Because the webcam image does not appear on the screen.
20 Sep 2019 20:55 - 20 Sep 2019 20:55 #88427 by MB RADIO
Replied by MB RADIO on topic Webcam
You should assign the webcam to an EXT (ex EXT1) and then send on air the EXT1
Last edit: 20 Sep 2019 20:55 by MB RADIO.
20 Sep 2019 21:26 #88428 by Medeiros
Replied by Medeiros on topic Webcam
The setting is correct.
And how do I ship Ext 1 to the air?
20 Sep 2019 21:33 #88429 by MB RADIO
with the EVENT EXT1
or the LIVE EXT1
21 Sep 2019 01:12 - 21 Sep 2019 14:54 #88430 by Medeiros
Ok, I got it.
Is there no way to enable the webcam via audio input detection when turning on the mixer microphone (Axel Oxygen 3000)?
It was just him to detect the audio input with the speaker's voice.
It associated an audio card with EXT 1 and another for EXT 2 ... out there.
Last edit: 21 Sep 2019 14:54 by Medeiros.
22 Sep 2019 22:29 - 22 Sep 2019 22:33 #88446 by MB RADIO
if your hardawre mixer has relay contacts you can use this USB card www.velleman.eu/products/view/?id=404880 to remote some commands on MB STUDIO.
your mixer has gpo so you can use gpo on air lamp to close a contact on the usb velleman card that will enable the talk button on MB STUDIO and consequently will open the webcam
GPO: 10 total, to control OnAir lamps or Telephone Hybrid.
Last edit: 22 Sep 2019 22:33 by MB RADIO.
23 Sep 2019 00:57 - 23 Sep 2019 00:58 #88451 by Medeiros
But with audio input detection it was easier.
I have to analyze this solution from Valleman.
Is it possible to put the webcam image in a small resolution and on the video? (example image).
Last edit: 23 Sep 2019 00:58 by Medeiros.
23 Sep 2019 01:28 #88452 by MB RADIO
Yes, if you click the button TALK a voice track is started so set te voice track in the screen zone that you want:
The following user(s) said Thank You: Medeiros
24 Sep 2019 17:49 #88461 by Medeiros
Using this USB card with Axel Oxygen 3000 ( www.axeltechnology.com/oxygen-3000/ ) can I configure MbStudio?
I want to activate the cameras by turning on the desk buttons and use two or three cameras at the same time.
If possible you can give more details.
06 Oct 2019 13:55 - 06 Oct 2019 14:00 #88530 by Medeiros
I already bought the USB interface K8055N.
If possible you can give more details?
Last edit: 06 Oct 2019 14:00 by Medeiros.
06 Oct 2019 15:38 - 06 Oct 2019 15:39 #88532 by MB RADIO
The card allow to close up to 5 digital inputs (0= ground, 1= open) (on board test buttons provided). So you should conenct at least 1 contact to the mixer.
With MB STUDIO you can use only 1 camera at the same time.
Last edit: 06 Oct 2019 15:39 by MB RADIO.
11 Oct 2019 00:34 #88559 by Medeiros
Thanks for the previous info.
Purchase three webcams from the Logitech C920 (FULL HD), but in MBStudio settings has a very low resolution, you can not do the HD for less.
What should I do?
And how to set as three in MBStudio?
Webcams using OBS (creating multiple scenes) have the maximum resolution. (I'm just using the HD).
Time to create page: 0.107 seconds
