No acquisition card !
  • gandrew
20 Feb 2021 18:19 #92606 by gandrew
No acquisition card ! was created by gandrew
I used MB Recaster Free 4.6.5.6 or 5.0.0.8 on Windows 10 and I got the same problem. I'm back in 4.6.5.6.
I'm using the default card of the PC.The "Acquisition card" field is empty but the "sound card listening" field is filled.
Please see the screenshot
File Attachment:
File Name: Imagestudioradio.rtf
File Size:1,508 KB
20 Feb 2021 18:35 #92607 by MB RADIO
Replied by MB RADIO on topic No acquisition card !
Maybe you want to capture a "loopback"? if so you must enabled the loopback in the options and restart
  • gandrew
20 Feb 2021 18:56 #92608 by gandrew
Replied by gandrew on topic No acquisition card !
Thank you for your answer.
I enabled "loopback". I restarted MB Recaster and now I get "illegal device number".
I can select the card in "acquisition card" but I've a loopback. :(
20 Feb 2021 19:06 - 20 Feb 2021 19:06 #92609 by MB RADIO
Probably the input that you want to use is not enabled in windows. Show me the cards that you have in windows control panel audio
me i have this:
Last edit: 20 Feb 2021 19:06 by MB RADIO.
  • gandrew
20 Feb 2021 19:22 #92610 by gandrew
20 Feb 2021 19:29 #92611 by MB RADIO
You must look at "enregistrement" not to "lecture"
  • gandrew
20 Feb 2021 19:42 #92612 by gandrew
20 Feb 2021 19:48 #92613 by MB RADIO
ok as you can see no entry is active. To activate it, you need to connect an audio cable to the corresponding jack
  • gandrew
20 Feb 2021 19:51 #92614 by gandrew
I've a cable with 2 speakers, which works !
20 Feb 2021 19:55 #92615 by MB RADIO
yes but you must connect something to record also
  • gandrew
20 Feb 2021 22:37 #92616 by gandrew
Ok I understood my mistake.
I've to loop the speaker ouput to the microphone input and in MB Recaster I select Microphone for the acquisition card.
Is it right ?
20 Feb 2021 23:40 - 20 Feb 2021 23:40 #92617 by MB RADIO
it depends on what you want to stream with MB RECASTER. If you want to stream computer audio then turn the MB RECASTER monitor card to MBRecasterMix
and choose the loopback card as capture.
If, on the other hand, you have a mixer and you want to stream the mixer audio then you have to connect the mixer output to the computer input with a cable and then select that input in MB RECASTER.
Last edit: 20 Feb 2021 23:40 by MB RADIO.
Time to create page: 0.076 seconds
