RDS
28 Jan 2021 16:59 #92457 by radioarc
RDS was created by radioarc
SALVE,
ABBIAMO DA POCO ACQUISTATO UN NUOVO RDS DELLA DEVA, LO SMARTGEN 5.0.
VOLEVO SAPERE SE C'E' UNA GUIDA OPPURE SI E' IN PROCINTO DI TIRLA FUORI PIU' AGGIORNATA
RISPETTO A QUELLA ESISTENTE CHE RISALE A DIVERSI ANNI FA.
IN QUANTO SEGUENDO QUELLA ESISTENTE ED UTILIZZANDO I CARATTERI JOLLY NON TUTTO FUNZIONA AL MEGLIO. CIAO A PRESTO
28 Jan 2021 17:13 #92458 by MB RADIO
Replied by MB RADIO on topic RDS
radioarc wrote: NON TUTTO FUNZIONA AL MEGLIO
Segui questa procedura per segnalare un problema: www.mbradio.it/it/guida/333-supporto-come-segnalare-un-problema
Time to create page: 0.036 seconds
