BASE SOTTO BIANCO IN PLAY LIST
  • rvllaradio
  • rvllaradio's Avatar Topic Author
18 Aug 2017 11:47 #83821 by rvllaradio
BASE SOTTO BIANCO IN PLAY LIST was created by rvllaradio
COME FACCIO A METTERE IN UNA COSTRUZIONE DI UNA PLAYLIST CON BIANCHI A METTERE UNA BASE SOTTO I BIANCHI STESSI?
18 Aug 2017 11:58 - 18 Aug 2017 12:00 #83822 by PLATIMUN
Replied by PLATIMUN on topic BASE SOTTO BIANCO IN PLAY LIST
Qui trovi l'esempio del notiziario , e la stessa cosa per mettere una base nella play list
www.mbradio.it/it/forum/9-mb-spot-gestio...ammare-il-notiziario
Cor.64
Last edit: 18 Aug 2017 12:00 by PLATIMUN.
The following user(s) said Thank You: rvllaradio
  • rvllaradio
18 Aug 2017 12:26 - 18 Aug 2017 12:27 #83826 by rvllaradio
Replied by rvllaradio on topic BASE SOTTO BIANCO IN PLAY LIST
HO VISTO. MA IO HO UNA PLAYLIST (CON CANZONI, JINGLE SEQUENZE ORARIE E BIANCHI) QUINDI COME FACCIO AL FILE BIANCO AD INSERIRE LA BASE CHE MI INTERESSA INSERIRE?
Last edit: 18 Aug 2017 12:27 by rvllaradio.
18 Aug 2017 13:40 #83831 by MB RADIO
Replied by MB RADIO on topic BASE SOTTO BIANCO IN PLAY LIST
Prima del file bianco inserisci la base che vuoi
  • rvllaradio
18 Aug 2017 15:27 #83833 by rvllaradio
OK MA CON CHE PROPIETà?
18 Aug 2017 17:07 #83835 by PLATIMUN
come nell'esempio del notiziario ,a tuo piacimento fai le prove del volume come sottofondo
  • rvllaradio
19 Aug 2017 10:33 #83838 by rvllaradio
perfetto ora funziona grazie a tutti
