2 problemini in uno
17 Jun 2009 12:49 #40280 by
2 problemini in uno was created by
MB studio 8.33 PRO
1. ieri eravamo in diretta, dalle 12.30, che doveva continuare fino alle 13.30 (minuto più minuto meno), invece Mb studio ci ha tagliato per qualche minuto (alle 12.49). Ecco il debug:
>    191105 - vivaradiobueminuti17.mp3
>    GR - TD - Cartella: D:\MB_Studio\Audio\Produzioni\Repliche\WRadioBue pillole\ - Stereo 128 Kbits 44100 Hz - Flag2: 17027 - Comment:WRADIOBUEMINUTI
>    GR - TD - Informazione - Actual: GR - TD -  - Timer: 80439.633394613
12:29:16    Next Click
12:29:16    Fade Out device: 5 - Speed: 1
12:29:16    Fine oggetto 80645.9852795539
12:29:16    ======================================================================
12:29:16    On air: 5 - EXT1 - Start: 0 - End: 0 (0) - Duration: 0
>    EXT1 - Rear Green In
>    prove Gioia - [1] Record from Realtek HD Audio - Flag2: 0 - Comment:
>    prove Gioia - playlist generale - Actual: prove Gioia -  - Timer: 80645.9926830363
12:29:16    RecordSetDevice: 1
12:42:22    Writing C:\Programmi\MB Radio\MB Studio\MBStudio.cfg
12:42:22    File closed 1
12:42:22    Save Genres.dat
12:42:22    Write MBTemp1.dat
12:49:37    BASS_ACTIVE_STOPPED Handle:-1342172012
12:49:37    Fade Out device: 11 - Speed: 1
12:49:37    Fine oggetto 81867.1372603615
12:49:37    ======================================================================
12:49:37    On air: 4 - D:\MB_Studio\Audio\Promo\Promo DoTheDance.mp3 - Start: 1.498605 - End: 37.87871 (-1) - Duration: 43.54612
>    GR - TD - Cartella: D:\MB_Studio\Audio\Promo\ - Stereo 256 Kbits 44100 Hz - Flag2: 17027 - Comment:PROMO
>    GR - TD - Informazione - Actual: GR - TD -  - Timer: 81867.1435906194
12:49:38    End RecordProc -1342172012
12:50:13    Mix out - Position: 37.48517 - Remain: 0.3935394 - End: 37.87871 - Duration: 43.54612
12:50:13    Fade Out device: 6 - Speed: 1.4
12:50:13    Fine oggetto 81903.135146538
12:50:13    ======================================================================
12:50:13    On air: 3 - D:\MB_Studio\Audio\Brani\Gonzo48k - Stereo Wave.mp3 - Start: 0.2585374 - End: 326.2393 (-1) - Duration: 331.5722
>    gonzo48k - stereo wave
>    prove Gioia - Genere:Indie-E - Anno:2008 - File:D:\MB_Studio\Audio\Brani\Gonzo48k - Stereo Wave.mp3
- Commento:Indie-E - Album:hi-fi lovers - Stereo 256 Kbits 44100 Hz - Flag2: 16401 - Comment:
>    prove Gioia - playlist generale - Actual: prove Gioia - 0000-dolumamegivesa_prove Gioi - Timer: 81903.1410676057
12:50:13    Fade Out Background 4
12:50:13    Fade Out device: 4 - Speed: 1
12:50:35    Next Click
12:50:35    Fade Out device: 7 - Speed: 1
12:50:35    Fine oggetto 81925.1105277454
12:50:35    ======================================================================
12:50:35    On air: 5 - EXT1 - Start: 0 - End: 0 (0) - Duration: 0
>    prove Gioia - playlist generale - Actual: prove Gioia -  - Timer: 81925.1197775709
12:50:35    RecordSetDevice: 1
13:12:22    Writing C:\Programmi\MB Radio\MB Studio\MBStudio.cfg
13:12:22    File closed 1
13:12:22    Save Genres.dat
13:12:22    Write MBTemp1.dat
13:18:12    BASS_ACTIVE_STOPPED Handle:-1342171995
13:18:12    Fade Out device: 11 - Speed: 1
13:18:12    Fine oggetto 83582.0804078168
13:18:12    ======================================================================
13:18:12    On air: 4 - D:\MB_Studio\Audio\Jingle\Erinita - Versione Completa 2.wav - Start: 2.860068 - End: 68.71249 (-1) - Duration: 80.9795
Che è successo?
2. Ho settato le configurazioni relative alla ricezione mail. Dopo aver settato tutto, ho premuto il tasto prova, e MB Studio mi ha confermato l'avvenuta connessione.
Ovviamente ho inviato due, tre messaggi per provare il sistema, ma nn arriva nessun messaggio (ho premuto ripetutamente il tasto sincronizza, mi viene fuori il messaggio: sincronizzazione avvenuta, ma nn arrivano i msg). Per ctrl che il problema nn fosse mio, sn andato sulla webmail, e i msg c'erano.
3. Piccola informazione? A cosa serve il pulsante Cornetta?
Grazie mille
17 Jun 2009 13:56 #40281 by MB RADIO
Replied by MB RADIO on topic Re: 2 problemini in uno
Che è successo?
Probabilmente in quel momento è entrato in esecuzione un altro programma audio che ha inizializzato la scheda interna interrompendo il Record from.
Prova a riavviare MB STUDIO.
A parlare con un auricolare usando il modem DIGICOM USB WAVE GPRS
17 Jun 2009 14:44 #40286 by
Replied by on topic Re: 2 problemini in uno
Bhè, che dire.... Grazie.....Risolto tutto (al momento, magari fra cinque minuti avrò problemi per altre cose, ma sperodi no).
18 Jun 2009 19:35 #40327 by
Mah, ho letto e riletto il log, ma nn riesco a capire:
Mi è saltata la diretta alle ore:
16:46:34
16:55:22     BASS_ACTIVE_STOPPED Handle:-1342171331 (ma questo me l'hai già spiegato, riesci forse acapire dipiù su questa specifica?)
17:30:38     BASS_ACTIVE_STOPPED Handle:-1342171320
17:58:23     BASS_ACTIVE_STOPPED Handle:-1342171304
e via dicendo....Grazie
18 Jun 2009 19:39 #40328 by MB RADIO
Quel messaggio indica che la cattura dalla scheda audio si interrompe: i motivi possono essere vari, spesso un altro programma tenta di accedere alla scheda inizializzandola e quindi interrompendo il flusso verso MB STUDIO (spesso questo comportamento è causato da Skype, MSN, etc)
18 Jun 2009 19:48 - 18 Jun 2009 20:55 #40329 by
Può essere che cade il flusso anche se skype è su un altro PC, il quale manda il segnale ad un mixer, e da qui rivolto a MB Studio per lo streaming ???
mentre le altre cadute? Ce ne sono un paio senza quel messaggio.
Last edit: 18 Jun 2009 20:55 by .
18 Jun 2009 22:53 #40333 by
era una domanda
19 Jun 2009 10:53 - 19 Jun 2009 11:14 #40339 by
che significa End RecordProc nel log?
>    prove Gioia - playlist generale - Actual: prove Gioia - 0000-dolumamegivesa_prove Gioi - Timer: 92329.8440655669
17:30:39    End RecordProc -1342171320
17:30:46    Next Click
17:30:46    Fade Out device: 7 - Speed: 1
17:30:46    Fine oggetto 92338.3890665932
17:30:46    ======================================================================
Last edit: 19 Jun 2009 11:14 by .
19 Jun 2009 14:12 #40341 by MB RADIO
Replied by MB RADIO on topic Re: che significa "End RecordProc" nel log?
siginifica che il processo di cattura è terminato
19 Jun 2009 14:16 #40342 by MB RADIO
No assolutamente.
Se i tuoi problemi sono causali, prova ad aggiornare i drivers della scheda audio.
Tieni presente che le schedine integrate nei pc sono costruite pensando all'ascolto della canzone col mediapleyer o allle telefonate con skype, ma non vengono mai testate in condizioni piu' professionali quali contemporaneo cattura e playout di piu' segnali, quindi alcune schede integrate ce la fanno ed altre no.
Comunque manda il debug completo per vedere la tua configurazione, istruzioni qui sotto.
Per favore, continua l'argomento in questo post e non aprire nuovi articoli sullo stesso argomento, grazie
19 Jun 2009 15:50 #40345 by
Te l'ho inviato. Speriam in bene.
;D ;D , creavo sempre argomenti nuovi perchè continuando a inserire msg sullo stesso thread il contatore delle letture va s, ma nessuno mi risp.
19 Jun 2009 15:58 #40346 by MB RADIO
Configurazione/Audio/Audio Buffer: il valore 1000 è troppo elevato, abbassarlo a 500
Configurazione/Opzioni/Priorita' è troppo elevata, riportarla su Normal.
Time to create page: 0.072 seconds
