RDS PIRA
26 Feb 2009 21:27 #36326 by
RDS PIRA was created by
Dear Maurizio,
i have installed a Pira RDS Coder. I can see on the radio display the text i have written in your software ( field "program servce" and "PS 2" in the folder RDS PIRA of your software ), but i can't get the song/artist information. I leave the PS 1 field blank. Is this right?
Can you tell what i'm doing wrong?
26 Feb 2009 23:41 #36330 by MB RADIO
Replied by MB RADIO on topic Re: RDS PIRA
Yes, it's right to have the Dynamic PS1 label blank. MB STUDIO will fill PS! with current song/program title.
If it's not the case to you please send the debug using menu' Help/Send debug to MB SOFT
18 Apr 2009 10:48 #38205 by
Replied by on topic Re: RDS PIRA
Dear Maurizio,
wii it be possible to change the way of displaying artist and title in your next update? When i use your internal program, the coder will not separate artist and title into 8 digits. Hope you understand what i mean?
19 Apr 2009 20:25 #38248 by MB RADIO
Dear Maurizio,
I don't think i'll be able to do so unless the PIRA encoder can do it automatically; i'll take a look to the pira documentation.
19 Apr 2009 23:05 #38254 by
I'm not sure, but i think with the pira software it works, so there should be a way.......
Time to create page: 0.087 seconds
