agenda - comando interno??
  • sasa
30 Sep 2008 05:33 #32241 by sasa
agenda - comando interno?? was created by sasa
06:46:05    Agenda - Comando interno STOP
06:46:05    Stop Click
06:46:05    Fade Out device: 11 - Speed: 1
06:46:05    Split reset
06:46:05    Fine oggetto 2731264.96563247
06:46:05    ======================================================================
06:46:05    TCP lost connection from 192.168.0.100
06:46:05    TCP Close connection 1 192.168.0.100
06:46:06    End RecordProc -1342160616
06:46:14    TCP Server - Incoming Connection from 192.168.0.100 - Virtual Socket: 1 - Index: 1
06:46:14    cscGetData 1: <- 192.168.0.100 NEXT
06:46:14    Admin command  from  - 192.168.0.100 - NEXT
06:46:14    Agenda - Comando interno NEXT
06:46:14    Next Click
06:46:14    Play Click
06:46:14    On air: 5 - EXT1 - Start: 0 - End: 0 (0) - Duration: 0
>    EXT1 - Linea in entrata 3
Ciao Maurizio ho problemi con lo split... mi esce sempre questo comando  Play Click o STOP Click ma in agenda non ho impostato nulla. mi blocca sembre lo split...
sai dove posso andare a trovare il problema?
Grzie
sasa
  • sasa
30 Sep 2008 10:25 #32249 by sasa
Replied by sasa on topic Re: agenda - comando interno??
mi si blocca sempre lo split lo trovo in play fermo..... help me!!!!! :&#39;( :&#39;( :&#39;( :&#39;( :&#39;( :&#39;(
  • sasa
30 Sep 2008 10:50 #32250 by sasa
10:30:36    Save Genres.dat
10:30:36    File closed 1
10:30:36    Write MBTemp1.dat
10:33:49    TCP Server - Incoming Connection from 192.168.0.100 - Virtual Socket: 0 - Index: 0
10:33:49    cscGetData 0: <- 192.168.0.100 ñSTOP
10:33:49    Admin command  from  - 192.168.0.100 - STOP
10:33:49    Agenda - Comando interno STOP
10:33:49    Stop Click
10:33:49    Fade Out device: 11 - Speed: 1
10:33:49    Fine oggetto 87900.6377405424
10:33:49    ======================================================================
10:33:49    TCP lost connection from 192.168.0.100
10:33:49    TCP Close connection 0 192.168.0.100
10:33:50    End RecordProc -1342177073
10:34:18    Automatic Click
10:34:18    On air: 5 - EXT1 - Start: 0 - End: 0 (0) - Duration: 0
>    base - [0] Record from SB Audigy 4 Audi - Flag2: 16 - Comment:
>    base - intrattenimento - Actual: base - 0000-dolumamegivesa_base.mbp - Timer: 87929.9381633129
10:34:18    RecordSetDevice:
0
ancora fermo per questo comando che non riesco a capire da dove viene.... :&#39;( :&#39;( :&#39;(
30 Sep 2008 13:11 - 30 Sep 2008 13:20 #32252 by MB RADIO
Replied by MB RADIO on topic Re: agenda - comando interno??
Sei sicuro che nello split in configurazione/rete è attivo il flag "Split slave"?
Inoltre si vede nel debug che lo STOP arriva dall&#39;altro computer, dunque potrebbe trattarsi di un flag di troppo che hai messo alle proprieta&#39; di qualche oggetto.
Inoltre sul master svuota la casella Remote Host e togli il click a "Aggiorna Automaticamente"
Last edit: 30 Sep 2008 13:20 by .
Time to create page: 0.087 seconds
