MB LIVE Windows
22 Oct 2026 14:16 - 22 Oct 2026 14:19 #104050 by Medeiros
MB LIVE Windows was created by Medeiros
Is it possible to implement buttons for the "Play," "Play All", "AutoPlay," and "Automatic" commands in MB Live for Windows, for remote use?
This would be to control the main studio.
Often, I need to manage these functions but am unable to do so, which forces me to use a different remote application.
Last edit: 22 Oct 2026 14:19 by Medeiros.
Yesterday 00:25 - Yesterday 00:29 #104052 by MB RADIO
Replied by MB RADIO on topic MB LIVE Windows
yes you can create agenda - internal commands
be sure the commands are not active
and the use it in MB LIVE
However, it is very risky to exit automatic mode from MB LIVE; if the connection drops and you are unable to reconnect, or you forget to return to AUTOMATIC mode, the playlist might come to an end, leaving the radio station silent.
From MBLIVE it is more appropriate to insert the DELAY command into the playlist to pause the playlist.
Last edit: Yesterday 00:29 by MB RADIO.
Yesterday 00:41 - Yesterday 00:46 #104053 by Medeiros
Replied by Medeiros on topic MB LIVE Windows
I need to use these commands because certain blocks are being forced in the programming.
And I do not want them to be issued.
I can address this by locking the blocks; however, if I unlock them, the system will play the previously forced block, given that MB STUDIO is in automatic mode.
I believe that by setting the option to "Play All," I can avoid this issue.
Last edit: Yesterday 00:46 by Medeiros.
Yesterday 01:15 #104054 by MB RADIO
would not be better to disable blocks and play the blocks manually as you like?
Yesterday 01:25 - Yesterday 01:31 #104055 by Medeiros
I did that—I disabled the blocks. But when I re-enable them, the block configured as "force" goes live and interrupts the direct feed coming from MB Live. Is there a better way to handle this?
By the way, here’s a suggestion: you should use a color that makes the blocks already issued in MB Live stand out better, as it’s currently a bit difficult to distinguish them since they appear in orange.
Last edit: Yesterday 01:31 by Medeiros.
Time to create page: 0.057 seconds
