Computer for using MBStudio software
15 Dec 2022 12:39 - 15 Dec 2022 12:42 #96852 by Medeiros
Computer for using MBStudio software was created by Medeiros
I'm thinking of buying a laptop with windows 11 the Xioami Book S.
But I have a question does MBStudio, MBlive, MBRemote, MBPlay work on this computer?
Because it is not Intel but ECNS Qualcomm Aqstic™: funzionalità ECNS fornita dal chipset Qualcomm® Snapdragon™ 8cx Gen 2 a livello hardware, l'applicazione software compatibile può variare.
This would be for remote use only and for small jobs not broadcast.
More details here: www.mi.com/it/product/xiaomi-book-s-12-4/
www.mi.com/it/product/xiaomi-book-s-12-4/specs
Last edit: 15 Dec 2022 12:42 by Medeiros.
15 Dec 2022 12:57 #96853 by MB RADIO
Replied by MB RADIO on topic Computer for using MBStudio software
Windows on mode "S" do not allow to execute MB SOFT softwares. It only allow to execute predefined applications for Windows Store.
Sometimes you can disable the "S" mode but it depends on xiaomi if it allow it.
support.microsoft.com/pt-pt/windows/wind...e5-c30b-93baebeebc85
15 Dec 2022 13:23 #96854 by Medeiros
Replied by Medeiros on topic Computer for using MBStudio software
According to Xiomi, the S mode can be disabled. What do you think there is no problem?.
15 Dec 2022 13:28 #96855 by MB RADIO
On ARM only 32 bits applications can run. MB SOFT softwares are all 32 bits but some componets used like ffmpeg are only 64 bits. (32 bits are still available somewhere i think)
It depends on what kind of job you have to do with that computer.
If you don't make broacast but only management with MB REMOTE or MB LIVE i think should be ok.
15 Dec 2022 16:44 - 15 Dec 2022 16:45 #96856 by Medeiros
Thank you for the informations. So the software works without problems having 32-bit programs.
I'm thinking of purchasing it for remote use with MBLive programs, MBRemote and MBStudio also works right?
Last edit: 15 Dec 2022 16:45 by Medeiros.
15 Dec 2022 16:46 - 15 Dec 2022 16:47 #96857 by MB RADIO
i cannot guarantee MB STUDIO will work without problmes.
MB REMOTE and MB LIVE should be ok but not sure about video.
Last edit: 15 Dec 2022 16:47 by MB RADIO.
