MB Remote
09 Apr 2022 20:49 - 09 Apr 2022 20:50 #95364 by Medeiros
MB Remote was created by Medeiros
Is it normal in MB Remote (1.70.3.5) for the list to be in black?
I can't get the settings predefined by me on the MB Remote in the music columns. I always have to change.
Last edit: 09 Apr 2022 20:50 by Medeiros.
09 Apr 2022 20:53 #95365 by MB RADIO
Replied by MB RADIO on topic MB Remote
the colors and settings are the same as the MB STUDIO you connect to.
09 Apr 2022 20:59 - 09 Apr 2022 21:00 #95366 by Medeiros
Replied by Medeiros on topic MB Remote
On mine the colors don't look like it.
The photo I send now is from MBstudio.
Last edit: 09 Apr 2022 21:00 by Medeiros.
09 Apr 2022 21:32 #95367 by MB RADIO
Probably the MBstudio data fodler is not c:\MBStudio but something else so MB REMOTE use the settings of that folder
www.mbradio.it/en/support/help/113-confi...onfiguration-network
10 Apr 2022 03:11 - 10 Apr 2022 03:11 #95369 by Medeiros
mine is in Z:\
Because mine is like this because it is using the server.
Last edit: 10 Apr 2022 03:11 by Medeiros.
10 Apr 2022 23:11 #95375 by MB RADIO
ok, for now MB REMOTE do not support that configuration, i will look to support it as soon as possible.
11 Apr 2022 00:45 #95376 by Medeiros
OK. I will be waiting.
Thanks.
