new user
  • davefrmn2019
22 Mar 2022 17:25 #95194 by davefrmn2019
new user was created by davefrmn2019
Hi Everyone,
Just installed MB Studio demo last night. I am trying to load a few categories for the playlist such as 60s, 70s jingles, etc. I have a slight learning disability so I'm having a little difficulity following a long. Are there any English tutorial videos available ?
Thanks.
22 Mar 2022 17:44 #95195 by MB RADIO
Replied by MB RADIO on topic new user
i'm afraid but no one made an english video tutorial. if you're learning to make a rotation or playlist start trying this: www.mbradio.it/en/support/help/115-playl...t-the-first-playlist
  • davefrmn2019
22 Mar 2022 18:18 #95197 by davefrmn2019
Replied by davefrmn2019 on topic new user
Can't seem to get songs added from my songs folders.
Not sure if its because I get this error no default editor selected.
22 Mar 2022 18:27 #95198 by MB RADIO
  • davefrmn2019
22 Mar 2022 18:30 #95199 by davefrmn2019
I was able to load a playlist but still not sure how to create separate folders to use in rotation.
22 Mar 2022 18:37 #95200 by MB RADIO
as far as i know no extra folders are required if you import the songs in the database.
when you compile a rotation for each item you can choose if you want to play a random song from the database or a random song form a folder that is in your hard disk. see here: www.mbradio.it/en/support/help/115-playl...ndom-song-parameters
  • davefrmn2019
22 Mar 2022 20:23 #95201 by davefrmn2019
I was able to create a folder for inserting jingles in the playlist but this really cant be tested in the demo because automation is disabled right ?
22 Mar 2022 20:28 #95202 by MB RADIO
yes, you cannot have AUTOMATION running, but you can manually load a rotation or playlist by clicking "Load Playlist"
and then click PLAY ALL to play it
but it will stop at the end of the list
at least you can listen how it play your playlist or rotation
  • davefrmn2019
22 Mar 2022 21:08 #95203 by davefrmn2019
oh ok thanks...please see attached JPG error that im getting when i try to open editor for a mp3 song.
22 Mar 2022 21:15 #95204 by MB RADIO
This is not important, it only happens if you click the button "audio Editor", I do not use it all, but if you have an audio editor installed on your computer (like ex: audacity www.audacityteam.org/download/ ) the file will be opened inside audacity (you must configure the path to your audio editor in MBStudio\Configuration\Options)
  • davefrmn2019
22 Mar 2022 22:43 #95205 by davefrmn2019
Ok that's what I needed to know.
Thanks
  • davefrmn2019
22 Mar 2022 23:57 #95206 by davefrmn2019
I couldnt location MBStudio\Configuration\Options  in the two programs folders, is there another area im suppose to be looking for it ?
