Where is CurrentListeners.txt
  • Polar
03 Nov 2021 17:20 #94077 by Polar
Where is CurrentListeners.txt was created by Polar
Hi all,
I'm using MB Recaster 4.2.3.2 Free version. I read on the website "Save current connections count to a text file CurrentListeners.txt ". However, I can not find the instructions on how to do this. Can anybody point me to a link where I can find this information, or maybe explain it here on the forum?
Many thanks in advance.
03 Nov 2021 17:49 #94078 by MB RADIO
Replied by MB RADIO on topic Where is CurrentListeners.txt
it's a really old version. try with latest: www.mbradio.it/en/component/rsfiles/down...tall.exe&Itemid=1670
  • Polar
03 Nov 2021 19:21 #94079 by Polar
Replied by Polar on topic Where is CurrentListeners.txt
I tried with v.5.0.2.0 (the latest). The default capture card is changed from "VAC Out 8" (as is used in the old version) to "Mix". "Mix" gives a very poor sound in the background with a lot of hissing noise. When switching to VAC Out 8, I get a very distorted sound. I had to revert to 4.2.3.2 in order to get my radio back online.
Is it correct to assume that 4.2.3.2 does not support CurrentListeners?
What could be the reason for the sound problems in 5.0.2.0?
03 Nov 2021 20:22 #94080 by MB RADIO
that old version of MB RECASTER do not have CurrentListeners.txt output
For ther audio card there are a lot of settings...see here www.mbradio.it/en/support/help/113-confi...-audio-card-advanced
And if you don't see the loopback outputs you can enable it in Options
  • Polar
03 Nov 2021 21:44 #94086 by Polar
As I wrote : "When switching to VAC Out 8, I get a very distorted sound." In other words, the default capture card is set to "Mix". But I can choose the VAC Out cards. The only issue is that the sound is very very bad, or only noise. Strange, because it works out of the box with v.4.2.3.2.
03 Nov 2021 22:32 #94088 by MB RADIO
As i wrote you can change some of this settings: www.mbradio.it/en/support/help/113-confi...-audio-card-advanced especially you can try to increase the audio buffer
