My sound card doesn't appear or connection lost
  • tavocantilloh
09 Sep 2021 20:44 - 09 Sep 2021 21:13 #93676 by tavocantilloh
When I open mb recaster Free and next plug a usb sound card this usb soundcard doesn´t appear in capture card, I have to restart mb recaster and then the usb soundcard appear.
That´s work fine in monitor audio card option.
I have installed mb recaster 5.0.1.7
En español:
Cuando abro mb recaster y luego conecto algun dispositivo de entrada como una interfaz de audio usb o una mezcladora usb, mb recaster no la detecta, no aparece en "Tarjeta de captura". Extrañamente la reconoce en "Tarjeta de Sonido Prescucha" y para que mb recaster detecte en "tarjeta de captura" debo cerrarlo y volverlo a abrir, lo cual es perjudicial ya que la transmisión se corta, y los oyentes que estén escuchando, dejan de escuchar.
De igual forma, cuando voy a desconectar mi interfaz de audio usb no desaparece de mb recaster , solo desaparece en "Tarjeta de sonido prescucha".
Last edit: 09 Sep 2021 21:13 by tavocantilloh.
10 Sep 2021 13:43 #93679 by MB RADIO
Unfortunately MB RECASTER FREE does not detect changes in the list of sound cards (sound card added or removed). I will try to add this function in the next update.
10 Sep 2021 20:18 - 10 Sep 2021 20:18 #93698 by MB RADIO
Last edit: 10 Sep 2021 20:18 by MB RADIO.
  • tavocantilloh
13 Sep 2021 16:07 #93716 by tavocantilloh
Replied by tavocantilloh on topic My sound card doesn't appear or connection lost
Thank you very much!
