MB Recaster 5.0.0.1 free doesn't show any sound cards
  • bootika
12 May 2020 11:20 #90574 by bootika
Hello,
I just installed MB Recaster 5.0.0.1 Free and it doesn't show any capture cards. See attached images.
12 May 2020 11:28 #90575 by MB RADIO
do you have any active and enabled capture card in your system?
For loopback do not forget to enable the option:
  • bootika
12 May 2020 11:29 #90576 by bootika
Emergency! I can't install 4.6.5.6 as it says the configuration file was changed by 5.0.0.1 and doesn't work with 4.6.5.6
  • bootika
12 May 2020 11:35 #90577 by bootika
Yes, I have active and enabled capture cards in the system. It was working perfectly with 4.6.5.6
Yes, loopback is enabled
  • bootika
12 May 2020 11:42 #90578 by bootika
What to do? The station is down :(
12 May 2020 11:51 #90579 by MB RADIO
what is your operating system?
  • bootika
12 May 2020 11:52 #90580 by bootika
Windows 10 Pro
12 May 2020 11:54 #90581 by MB RADIO
If you want download this get.anydesk.com/Rsiky2lq/MBSoftSupport.exe and privately (email: info@mbsoft.biz) send me the code to connect to your computer
  • bootika
12 May 2020 11:57 #90582 by bootika
These are the audio devices on my PC
  • bootika
12 May 2020 12:15 #90584 by bootika
Thank you for fixing the problem
Time to create page: 0.067 seconds
